Allison 6sp: newbie
jmac
Jun 3, 2016
I have 09 3500 with efi live around 200 rwhp added ,150 fass ,transgo jr and 5 inch exhaust newly installed . My ? is during shifts it falls on its face I'm looking at fuel rail pressure not seeing a drop. Any suggestion ?
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
Trans probably hasn't had time to learn yet.. And probably won't like that power level.
jmac
Jun 3, 2016
He said around 200 more on the hot tune. Tranny also has a transgo Jr installed.
jmac
Jun 3, 2016
Yea I thought about that but it's shifting like that in all the tunes. I'm going back to see him tomorrow.
jmac
Jun 3, 2016
Well seen my tuner guy yesterday and my truck is defueling. It's has low fuel presure at ideal he recommends shims or a race plug . Any suggestions on wich one would be best for myou truck.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
If he gave you a tune with 200 additional horsepower for a stock transmission with just a transgo the best thing for your truck is a new tuner.
Second, if your pressure relief valve is in fact leaking, (Checking rail at idle is not how to determine this) then I would do a race valve. I've had mixed results with shimming. And I've yet to have an issue with any of the race valves I've installed.
jmac
Jun 3, 2016
He crimped the line for the return and the rail pressure went at idle so that's how we determined it was leaking n6 . And as far as the tunes I ask him yesterday about that . He assured me as long as I didn't beet on it hard all the time it would be ok. I guess I need to inquire about littel more
DefiantArms
Limp Mode Cowboy
Jan 28, 2016
897
St. Augustine, FL
See if he will put his money where his mouth is and warranty your trans with that "200hp" tune Bc I had a 125-150? From rob and limped mine more than once
jmac
Jun 3, 2016
Yes that's my tuner. I don't run the shit out of on the hot tune and so far it hasn't went into limp mode. The tunes are clean he does really good work and we think the problem is the low frp . I'm going to install the race plug and go from there.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Find somebody to look at it who understands how a high pressure common rail diesel engien fuel system works. Even if the popoff was leaking, crimping the rubber hose WILL NOT hold back 26K+ PSI, it would blow up in your face. If he crimped off the main return for the engine, then I'm surprised it didn't blow all your return lines out of the injectors, and if it didn't blow them out, it should have stalled the engine. This is NO test to check for a leak. This test proves NOTHING. Common rail injection uses a pressure bypass valve for the injectors, so they must bypass fuel to open, and if the rail valve is in fact leaking, you can't just crimp the rubber hose off to check it, you put the hose in a jar, and see if fuel bypass's the valve(AKA bottle test). This sounds like a tuning issue, and I'm with all above, 200 ACTUAL RWHP increase will put your trans on SERIOUS borrowed time. I seen theres a bunch of tuners on Ebay selling tunes this big, but like a local tuner to me, they don't care when your trans bites the dust, somebody else just got some more work.
