LLY: newbie with coolant problem
campingworld ut
Dec 28, 2013
im new here and need some help. i have a 2005 2500hd and the issue is with the coolant tank i keep having antifreeze coming out of the overflow tube when the truck is idling and after leaving the block heater plugged in all night and the next morning there will be antifreeze on the ground from the tank. there is no air bubbles in the tank while the truck is running and the coolant is clean and the oil has no milky look to it and i have also replaced the pressure cap and it stopped for awhile and now its doing it again but the cap did come from oreily autoparts so it could be junk but i dont know. any help would be great. thanks
TLyons90
Apr 22, 2013
1,631
Greenville, SC
First off welcome! 2nd my first thing to do would be return the cap for a new 1 and give another go for giggles. Also make sure it's fully tightened as well as not having your coolant tank overfilled with fluid!
1,865
Is the upper rad hose still hard if you check it in the AM after the truck has been sitting not running all night?
