Newbie on wheel offsets
Farney88
Jun 9, 2016
I have an 06 Silverado stock height and want to keep it stock height for truck pulling. How much offset can I have with an 18"? same for a 20"? haven't made my mind up if I want 18s or 20s.
Thanks!
jliddle
Jun 30, 2012
331
NC
Offset will be dependent on the width you decide to go with
For example most 20x9 will be "0" offset. Most 20x10 are around -24.
Drrrty
Dec 26, 2015
90
20x10 -24
NinjaMax
WTF!
Oct 3, 2012
1,266
42
Severance, Colorado
Lots of options in a 9 and 10 wide, a lot of 10x brands don't go lower the a -19. 9x you can find positive all the way to a -12...I'm sure there's bigger offset, just not very common...I ran 20x9 with a -12 on my 05, t bolts all the way out and drop shacked in the back. Very minor trimming. Good luck, post up some pics with what you decide
Drrrty
Dec 26, 2015
90
What kind of trimming did you do to fit those?
I had to cut some of the liner out and cut and folded the pinch weld back than very slightly trimmed the bumper. I only rub on full lock backing up and also rubbed the washer reservoir but I moved that further forward as well. I'm running 305-50-20
Farney88
Jun 9, 2016
Thanks for the info. I'm thinking 20x10 with a -12 offset? or a -24? But i was told on stock height -12 is all you can fit.
Drrrty
Dec 26, 2015
90
You can make anything fit. Just depends on how bad you wanna make it fit
Drrrty
Dec 26, 2015
90
Here is my old setup, -12..no bolts, front is slightly wider then rear from the control arms flexed out.
Sits pretty tall for having no bolts... Mines got bolts out and 20x10
