New wheels and tires finally!
Bustedknuckles
Honey Badger
Sep 25, 2010
1,308
33
Hagerstown MD
20x10 BMF Novakanes with 305/55/R20s. Now the question is how to get them to clear??? They rub the metal on the rear of the front fenders :/
56taskforce
1,081
56
Dam they look good:thumb: sucks they rub. The only ways I can think of stopping it would be lift it or paint and body work.
AKlowriderZ71
May 14, 2012
719
Wyoming
Look up the NorCal fender mod. You'll also have to remove those front mud flaps. I run 33x12.50-18's on my 2001 at stock ride height.
Truck looks good!! :thumb:
DIESELMAFIAPER.LB7
<----new hotness
Jan 17, 2010
5,163
12
idaho
Mines leveled and it'll clear stock height and a 20x10 on a 305/55 ain't going to work backspace and offset won't let it clear correctly my 20x9 zero offset rubs like a bitch with my bars all the way down at the track and believe me I cut the hell outta the fender
Bustedknuckles
Honey Badger
Sep 25, 2010
1,308
33
Hagerstown MD
These were on a duramax, bought them from a friend actually. I guess ill have to meet up with him and see what he did to make them fit. They actually work now, they just rub a little bit at the one point.
DIESELMAFIAPER.LB7
<----new hotness
Jan 17, 2010
5,163
12
idaho
I meant a 20x10 wouldn't fit with a lowered or bars all the way down it'll always rub because of the -24mm offset my last set was that way if you turn the front end up it should clear fine
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
I run a 20x10 with a lot of negative offset on my lowered truck, (front bolts removed).. With 285/55/20s.. Fender clearance was a must ;) actually almost rubs the washer tank lol.
