New track times
2005LLY
Sep 18, 2011
379
Went to the track Saturday this is the best run of the night, I'm on the left.
2005LLY
Sep 18, 2011
379
Truck is smoke free except on the launch. I think I have more in it once I get my set up right
rickettzusaf
Nov 30, 2011
276
Goldsboro, NC
100 overs, dual cp3's and a 68mm? It doesn't say in your sig but what about your trans? Built or not? Who's tuning? Congrats on the runs though! I took almost 2 years to get my suspension set up right. It's worth it.
2005LLY
Sep 18, 2011
379
Yeah it's a fully built trans, every billet SunCoast part you can buy, it sees a stock tune 5 days out of the week, then a tow tune for hot rodding for the weekend, then big one for the track.
Duramax tuner tunes it
Benltr
Jan 17, 2012
104
You should run atleast a #3 or #4 tune each week and than use #5 to the track so the difference in power isnt that much and your tranny can hold it and be 100% efficient. Every time i go the track, i turn it into #5 and gives it a couple pulls on the street 1-2-3-4-5 before going all out at the track...
just my 0,02...
2005LLY
Sep 18, 2011
379
My newest track time was a 7.906, I think it's got 7.8x in it if I shed some weight and mess with tire pressure.
Went with billet shafts because I stripped the c2/p2 planetary gear in the transmission and my buddy broke his input shaft launching his so I didn't want to fool with it again. And future plans on truck are
Rods
Pistons
Main studs
Key everything
Valve springs, push rods, and cam.
Friday I am getting a ppe intercooler, and Profab headers and 2" up pipes. It'll stay stock long block till end of winter or middle of next summer. I want to run either the 63.5 billet cheetah with a gt4508r twins. Or my current cheetah and gt4508r.. Or if I keep pullin ill run a Danville 72mm with a 2.5 cover. I'm shooting for 800hp on fuel which should be obtainable with my fuel and either of those turbo options. I've also got a zex kit on it for when I wanna really beat on the truck lol.
THduramax
Will it ever end!
Aug 15, 2012
407
Flaherty, ky
Hell funk made several 7.2 runs on stock motor... And sprayed the bawls outa it.. Best I ran was 7.8... Had 7 out of 8 rods bent!!
SickLL7Crenshaw
Billy The Kid
Mar 10, 2013
1,088
Mexico
Ive went 7.9 in the 1/8 when I ran my 12.4 with a massive boost leak caused by a broke motor mount. Looking for a 7.7 this weekend and faster then a 12.4 hopefully.
High balance rates can show if you have bent rod as the cyl is loosing compression. Other then that do a compression test if your worried I've been 600+ for almost 2 years now on stock headbolts 55psi.
