Hi
Noob to EFI. Understand download/upload.
1. I tried to load Neens tow tune for my OS. It says something about 1kb? and mine is only 512k?? What this mean?
2. On my dashboard, I tried to add gauges, specifically actual fuel pressure in place of barometric pressure, it displays the actual fuel pressure but still says barometric. How to change to say actual, on my desired pressure it says it.
3. I also have another tune from a programmer. When I look at those tables the only parameters changed are the throttle based injection quantity. On another diesel forum I asked this same question and was ignored. Can someone here explain if what Im seeing is actual. Its a 135hp tune but no timing adjustments made to this tune. Does this mean the timing is stock, when I compare it to my stock LB7 tune the only thing changed IS the TBI quantity.
Thanks
Lawrence
Thanks
Lawrence
