For the people who enjoyed the old footwell headlight dimmer switch like on older cars....
I have put together a kit that allows you to add the old foot-actuated dimmer switch!
The nice thing about this kit is that you can retain function of the factory dimmer switch on the turn signal stalk. So if someone else is driving your truck and doesnt know about the foot-dimmer, he/she can still use the turn signal stalk dimmer normally.
The kit uses wires that are color-coded to the factory wiring for easy installation, and only requires tapping into two wires. The switch also does NOT require you to drill through your floor, so there is no risk of rusting/water leaks. The switch can be mounted anywhere on the driver side floor with the included mounting hardware. The switch is a high quality heavy-duty unit with a nice solid "click" action, and has a black all-metal switch body with rubber cap on the top of the button. These are ready to ship now.
Included in the kit:
Foot dimmer switch with rubber button
Color coded wiring
Scotch-lok connectors for easy install
Mounting hardware with stainless bolts
Installation instructions.
Price is $49.95, with a lifetime warranty!
Ben
Color coded wiring
Ben
