New Numbers
DMAXchris
It’s only temporary!
Apr 28, 2009
2,273
Natrona Heights PA
Finally got to put it on the rollers after the trans & EFI.
Last year with PPE standard and stock tranny:
434hp 756 ft/lbs
This year with an SCIV,EFI,Lift pump
528hp 1103ft/lbs
Pretty much what I figured. The contest was 3 most consistent pulls and was won by a Cummins. He had only a .04 horsepower difference in 3 runs.
I'm not very into Dyno numbers but its nice to know what is there.
DMAXchris
Apr 28, 2009
2,273
Natrona Heights PA
Just curious, but what made you go with the 1054 TC?
The lower stall & the fact that twins are in my near future. It will let them light real nice at the line, but not produce so much boost that I spin the tires. And it has upgraded internals. I can build 15-20 psi without pushing through the brake.
dmaxn04
Mar 1, 2009
186
Ocean Springs, MS
How does it work for you on the stock single?
