New non Duramax build
02greysixer
1,829
North Central FL
Picked up this gem over the weekend. 84 k5. It's going to be the recipient of my refreshed and tweaked 6.2 Detroit. It was a factory 6.2 anyway so that makes it easy. Body is remarkably straight, no dents bigger than a nickel and almost totally rust free. Plan is to try my hand at an auto tranny rebuild with the 700r4, maybe do an add a leaf lift, trim the fenders and lower bump stops enough to fit skinny 38" tires, Lincoln lock the rear end and possibly a paint job. Should be a fun truck to beat on
Big Block 88
Multiple choice muscle
Nov 3, 2008
4,665
Kansas when I am home
I had a 700 built that survived 500 horse small blocks and dozens of mud pits and tug a trucks... They don't suck.
I love those old trucks man good luck and keep us posted.
02greysixer
1,829
North Central FL
Even turbo'd and with more fuel being fed to it I don't think my old 6.2 is going to put out close to 300hp. Let alone 500hp. I want to keep the 700r4 for overdrive because I will drive it on the highway quite a bit. I've seen a well built 700r take some abuse
02greysixer
1,829
North Central FL
Yeah I had a 99 k2500 I put 38s on with stock gears. I tuned the tranny with efi to not shift to 4th and lock the converter in 3rd. Worked great :D
I will eventually regear this one though with lockers
02greysixer
1,829
North Central FL
Thanks guys. Been thinking about it today some and I'm considering using a mechanical turbo 6.5 engine instead of retrofitting the 6.2 with a bunch of 6.5 parts (turbo, manifold(s), injectors and possibly serpentine belt system). By the time I source all those parts I could probably buy a complete 6.5. Only thing I don't know is will my mechanical db2 pump bolt up in place of the ds pump used in later 6.5s?
