LB7: New Motor Build Porn !
chevytuf01
Dirty Deeds
Jul 2, 2010
261
Rileyville Virginia
Well time to get this motor together .. building a 2.6 truck with some new pretty parts :happy2:
Fingers Cast .020 Pistons
Carrillo Rods
ATI Damper
ARP Main Studs
Clevite Rod/Main Bearing
GM Cam Bearings
SunCoast Flywheel
Next i need to figure out which cam to run and what size injectors.
Thinking about tryin to run a s480 with a 2.6 cover with a t6 1.10 ar
chevytuf01
Dirty Deeds
Jul 2, 2010
261
Rileyville Virginia
Nice choices! I went with fingers pistons in my build and they have been great so far.
Yes i wanted a set when i first seen them ... and then i decided to build a motor and it was a no brainer
Looking forward to seeing how it all comes together and what she can do! Good luck with everything install wise!
Thanks im pretty excited my self to see what the outcome is as well !
chevytuf01
Dirty Deeds
Jul 2, 2010
261
Rileyville Virginia
Well Finally Got Started On Putting The Motor Back Together ... Got The Crank In And Tq ... The Cam In Rings Cut ... Pistons are Ready To Go In :woott:
Mikey
Drag Racer
Jun 13, 2009
560
3
Nice!
But No AF Cam? Which one are you gonna run?
Best to put one in based on everybody's input; while your in there.
Could be your cheapest insurance:thumb:
Mikey
Drag Racer
Jun 13, 2009
560
3
Oops Hamilton 199-207-110 Cam
Naaa i thought about doing a girdle but i was to far along at the machine shop so ill see how the stock main caps and main studs hold up
Is that an alternate firing cam?
If not, here is an important quote from IdahoRob;
So the engine with the alternate firing order cam after a season, no problems with the crank. The other engine with the standard cam, had a crack that showed when Fluxing.
Perfect test? Maybe not but both my SoCal race engine has the alternate firing order cams in them now.
chevytuf01
Dirty Deeds
Jul 2, 2010
261
Rileyville Virginia
Where do you plan to pull? There's a new PPL 2.6 class being put on by Power Pulling Productions covering Western PA, Eastern OH, and W.V.
Ill Pull Va And Maybe A Few Pulls Up In PA .... There Is Enough Pulls In Va To Keep Me Going .. And The Truck Wont Be Ready Till May Or June So It Will Be A Short Season This Year For Me
I don't hear from you in awhile and now I read this... Good luck with the build :thumb:
Sorry Derek I Kept This On The DL For A Few Months Till I Got Everything Back And Stated Putting It Together
They don't sell them. maybe if you ask nicely he can build one though?
Ben I Didnt Think It Was .. Hope The Cam I Have Helps The Monster Spool Up LOL
