I guess we need to become electricians now to work on these things! I love the "remember to check expiration date on gloves" part, I thought only Hybrids were doing this, I guess now its coming across the board.The new Duramax engines are equipped with Bosch piezoelectric injectors that operate at high voltage, indicated by the orange color of the injector harness. Do not make contact with the fuel injector harness, ECM or fuel injectors while the ignition is in the on or run position. Use certified, insulated Class 0 gloves rated at 1000 volts. Remember to check the expiration date of the gloves. The ECM supplies high voltage and provides the ground. Voltage is supplied upp to 160 volts at 20 amps, and can peak up to 240 volts. This causes the injector to open. The capacitor discharges through an injector for initial opening and holds open with 12 volts.
