Allison 5sp: New gmax5 kit running hot
Justmikedmax
Dec 26, 2016
20
Clermont FL.
Hello everyone
New to the forum ,hopefully someone can shed a little light on a problem I'm having . Just finished up my gmax5 kit in my Allison last week and have put around 300 mikes on it . Has been running high temps (230-240 ) the whole time . Normal driving no load ,highway and around town . I have torn her back out and checked all clearances and tolerances and I'm stumped ,I did find the c2 clutch hub thrust washer had some good wear on it ,(was new when installed ) . I've been scratching my head for days now don't wanna just slap her back in and have to pull it out again . Hopefully someone has some insight .
mebob2001
Riverview, new brunswick
Is the cooler plugged? Did u change the torque convertor to one that creates more heat? But it shoulsnt run that high not matter what. Take it back and ask questions. Also did you have a failure which made u build it? If u did the cooler.might be plugged up
Sent from my SM-G903W using Tapatalk
