New Downpipes now available!!
RickDLance
1,276
14
After jacking with the foreign made down pipes and all the trouble we had with them we decided to go back to making our own.
Our new LLY, LBZ, LMM dp is mandrel bent, tig welded, ceramic coated and wrapped.
Our new LB7 dp is also mandrel bent, tig welded, ceramic coated, and will fit the emissions models too!!
Best of all they are 100% made in USA in our shop and they are the same price as what we were selling the foreign stuff for!!
Check our website for details. www.profabperformance.com
RickDLance
1,276
14
If you bought one from me then I'll warranty it even if my supplier won't. ;) Here's the new LLY, LBZ, LMM pipe.
DaveB
Sep 6, 2009
409
Northeast Indiana
Very nice! I have the old one, so far so good. I did go ahead and cut the mount tab off so I didn't have to worry about it breaking or putting a hole in the pipe.
Harbin_22
3,858
Southern Indiana
The tab breaks from engine flex. If you either put a bolt through the stock drivers side mount or aftermarket mounts, it won't break. I think the only way to keep it from breaking would be a strap type that wraps around the pipe and not welded directly to the pipe. JMO though
Nice piece btw. Will be ordering one for a buddy shortly.
RickDLance
1,276
14
Here's the order of tubing we just got in for down pipes.
RickDLance
1,276
14
OK, the down pipe contest is done!!
I had a total of 3 correct guesses so I'm giving out three downpipes. The correct answer was 270 pipes.
Congrats to the winners and I've sent you all emails!!
