LBZ: New cp3,still p0087!?!
Devon
broke my curse
May 2, 2010
807
Hinsdale ma
Ok after doing the cp3, still only getting 19,650 at wot..what else possibly could it be? Injector rates are all good.
paint94979
Beer Nazi
Sep 18, 2006
11,715
I have had a race valve for over 25,000 miles and have not yet had an issue with it... but it is def. worth ruling out.
02bigstrokin
Sep 9, 2008
882
What makes you think it is the race plug? Just curious
Some people don't have any problems with them like nick said but I've had 2 llys that were falling off rail just like yours, we put a stock shimmed valva in and it fixed it. Jmo
Devon
broke my curse
May 2, 2010
807
Hinsdale ma
Ok I may try that.anywhere I can get a stock valve for cheap? Also,what else could I check besides that and injector return rates? My airdog is pulling fuel so that is working right.. Maybe install a sump on the tank?
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
40
Houston, TX
I've got a buddy with a lmm and the same mods as me except he has the ppe race valve and ported fittings. His truck constantly throws the P0087 low fuel press code. May have to try the stock valve with a shim to see if it helps.
sent telepathically via rooted ThunderBOLT
Devon
broke my curse
May 2, 2010
807
Hinsdale ma
Yea this is really starting to piss me off, on top of that I have a boost leak coming from the intake bridge I belive. I don't think its the injectors because on the smaller tunes it holds good rail.
Devon
broke my curse
May 2, 2010
807
Hinsdale ma
Robs as of right now, also have dustins too..robs race tune desires 27,500 from what the edge cts reads Only getting 18-20k though
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
So more than likely it is mechanical.. I was thinking it could be something in the tune... do the bottle test it is easy.
Sent from my PC36100 using Tapatalk
Texas Chevy
1,103
Vista, Ca
I had a race valve in and the truck ran fine then one day at highway speeds truck fell on it's face and threw codes limped to 55 mph and I had to stop to get it to move again. Put the rce valve out and the truck runs fine I only get the code on the race tune now.
Devon
broke my curse
May 2, 2010
807
Hinsdale ma
Could my injectors be shitty? Even if all the balance rates where ok? Also would I benefit from a hellmann sump?
5,847
x2 if no fuel found, return rates on each injector needs to be tested
See above, and yes they could be bad. a hellman sump isnt a bad idea but not required GO DO A BOTTLE TEST FIRST!!!!!
