New Build won't start
[email protected]
08 lmm long bed
Jun 12, 2013
las vegas nv
im new to dmax im using a engine outta a kodiak i believe lly cause it had two oil filler necks and oil sump was on other side but i used the bottom end of that motor with all my lmm stuff f.a.s.s pump industrial injectors race 1 and stage 2 turbo but cant seem to get the truck started says it has 6200 psi on cp3 i also changed i believe the relucter wheel or whatever its called behind the timing cover what problems am i running into can someone help
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
First, you should start a new thread. I will do that for you.
LLY has visible injectors yet has an Injector Control Module, and an early ECM.
It has 1 less tooth on the reluctor wheel, and a different bolt pattern.
Starting with the LBZ, EVERYTHING is different except filters. Everything.
You can swap parts back and forth, but you must know what up.
