I have a pull coming up in a week that requires a neutral safety light. Keep in mind it is my dd so with that being said, is there a easy way to do it being able to disconnect it after the pull?
Yes, there is a park neutral signal off the Trans connector that you run back to a light and groubd the other end. I dint have a 6sp diagram at work or else I could tell you what wire
I know on my 03 there is a fuse that only gets power key on in park and neutral. I wonder if 06 is the same way? If so you could probably run an LED off that fuse without effecting anything.
If it is anything like the last 5 yrs, they bark loud but don't have much bite. Dylan and I had everything last year, worked all hours to get ready, got there and they checked nothing
I've heard they don't check much but it would be my luck this year they will check everything, I know last year they were saying no street trucks so guess the plates will come off lol
