Negative offset question
dura07
Feb 1, 2014
29
Montgomery,TX
I have a 07 classic 2500hd with 17 inch wheels now looks like slandered offset with 285 70 17 grips. I'm looking to just to a 20 with the nasty -44 offset to have the wide wheels, truck sits level now and wondering if this is possible.
whitetrash21
put on da damn helmet day
Apr 29, 2008
4,929
Vegas
Its gonna rub. You'll need to do some cutting just to make it drive able. That still won't stop the rubbing at full lock or when turning up/down driveways. I'm assuming a 10" wheel??
Mar 13, 2012
Bham, AL
Dura07 is your truck leveled from stock? I'm lifted 6 inches and running 35x12.50 and wanted to put 18" wheels with -44 offset. It is a costly trial and error and I'm not into rubbing.
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
these are 305/50/20s on 20x10 -12s. They rub a bit but the bars aren;t cranked and I only trimmed the valence.
whitetrash21
Apr 29, 2008
4,929
Vegas
Ya 10 wide, we'll if it won't work it won't work
These were 20x10 with a -12 offset, 305/50-20 tires. I had the valance cut and the pinchweld on the back of the fender cut and hammered flat to stop the rubbing.... it still would with the wheel locked. If you've leveled the truck,run 285's, and cut the valance/pinch weld, you may be able to get away with running a -44 but you're gonna get some rub no matter what.
b16gsr
504
LS MO
Here is a setup I did a year ago:
20" X 12" Fuel Mavericks black and milled -44mm offset
305/55/20 Nitto Trail Grapplers
Check out the bead flex I had to get them to mount:
Here is a few images of them all done:
Pretty square mounted:
They rubbed everywhere.
