Help: need you mikey!
turbo-max
WaaaZaaaa
Aug 9, 2006
1,037
56
Tampa, FloriDUH
as you may or may not know i have swapped a dodge cummins engine/OD trans in to my 1989 chevy from a 92 D250 truck, anywho, i need to know wich wires (colors) to hook to what to make the Over Drive come on, i know what plug it is, just need to know what does who. thanks! :D
15,681
I will check and see if I have a wiring diagram for it.
15,681
Orange/ lt Green wire at trans goes to ECM at pin # 55 to activate O/D.
turbo-max
WaaaZaaaa
Aug 9, 2006
1,037
56
Tampa, FloriDUH
update...okay, i wired in a toggle switch to power(hot+) the bigger of the two wires coming from the top plug in the trans, and the O/D still does not activate, but id did work fine in the dodge...any ideas? thanks ~jeff
