LB7: need some efi help
MuscleTruck03
Wants a turbo!! or two...
Mar 10, 2010
369
north ogden, ut
hey guys Ive got a couple tunes Im trying to put into a dsp5 but when I upgrade the os to dsp5 it says I have a bunch of "out of range calibration" but when the tune was alone it was fine?? what am I not doing right?? thanks guys
btw I have efi v1
darkness
1,317
380
vegas
Sounds like you just uploaded the new os for the dsp5 switch. You need to fill all 4 switch positions with tunes. Someone correct me if I'm wrong
dracing70
SH--- GETTING EXPENSIVE!
Jun 12, 2007
1,210
45
mantua, oh
no u r correct the other four positions will be restored to a base position u just need to change the required tables to b within tolerance. not a big deal at all this is normal
Oct 16, 2008
948
12
Idaho
why would the tables be ok on a non dsp os though? sorry Im a rookie :eek:
You're not using any of the tables that are out of calibration when it's a non-dsp calibration. Once you change it to a dsp os is when you need to populate the tables for it to be a functional dsp tune. Make sense?
There is LIMITED space in the ECM for switchable tuning, to work with those constraints we've limited the number of tables that can be changed in the DSP environment.
The base file of a DSP tune contains all parameters of the ECM. Positions 2, 3, 4, and 5 contain a limited amount of tables that can be changed.
Once you flash the DSP file into your ECM, you need to populate positions 2-5 so they are not the same as your base tune.
Cheers
Cindy
MuscleTruck03
Mar 10, 2010
369
north ogden, ut
so I need to flash my ecm with this new dsp5 and then go back and put in my 2-5 tunes? I tried putting in the other tunes in 2-5 and its still showing a ton of out of range stuff
MuscleTruck03
Mar 10, 2010
369
north ogden, ut
Out of Range calibration summary: 12:21:48 am, Monday Jun 21, 2010
EFILive Custom Calibrations.DSP Program #2
{A2102} DSP #2 Throttle Base Injection Quantity, contained one or more out of range values when loaded.
{A2109} DSP #2 Torque Limited Injection Quantity, contained one or more out of range values when loaded.
{A2110} DSP #2 Base Torque, contained one or more out of range values when loaded.
EFILive Custom Calibrations.DSP Program #3
{A3102} DSP #3 Throttle Base Injection Quantity, contained one or more out of range values when loaded.
{A3107} DSP #3 Injection Timing (C), contained one or more out of range values when loaded.
{A3108} DSP #3 Injection Timing After Pilot (C,D), contained one or more out of range values when loaded.
{A3109} DSP #3 Torque Limited Injection Quantity, contained one or more out of range values when loaded.
{A3110} DSP #3 Base Torque, contained one or more out of range values when loaded.
{A3111} DSP #3 Fuel Pressure Base, contained one or more out of range values when loaded.
EFILive Custom Calibrations.DSP Program #4
{A4102} DSP #4 Throttle Base Injection Quantity, contained one or more out of range values when loaded.
{A4107} DSP #4 Injection Timing (C), contained one or more out of range values when loaded.
{A4108} DSP #4 Injection Timing After Pilot (C,D), contained one or more out of range values when loaded.
{A4109} DSP #4 Torque Limited Injection Quantity, contained one or more out of range values when loaded.
{A4110} DSP #4 Base Torque, contained one or more out of range values when loaded.
{A4111} DSP #4 Fuel Pressure Base, contained one or more out of range values when loaded.
EFILive Custom Calibrations.DSP Output #1
{A0118} DSP Output RPM Min, was out of range when loaded.
{A0121} DSP Output Coolant Max, was out of range when loaded.
{A0122} DSP Output Coolant Min, was out of range when loaded.
{A0123} DSP Output Torque Value Min, was out of range when loaded.
EFILive Custom Calibrations.DSP Staging
{A0139} DSP Staging Fuel Limit, contained one or more out of range values when loaded.
these are the main ones I keep seeing, even after I populate each dsp# I used to be able to make these in 2 seconds but I havent done one forever and forgot everything!
MuscleTruck03
Mar 10, 2010
369
north ogden, ut
After converting to dsp5 run the lb7 script. That's prolly the issue your having.
nailed it! thanks for the help guys! also does anyone happen to make a beginners guide to efi tuning? Some of this stuff I get and others I am totally lost and with this kind of stuff I dont want to experiment too much!
MuscleTruck03
Mar 10, 2010
369
north ogden, ut
well thanks for the help guys :hug: but my dads lb7 is now showing these codes, any suggestions?
"glow plug feedback circuit A" epa
barometric pressure (baro) sensor performance EPA
barometric pressure (baro) sensor performance EPA pending
"glow plug feedback circuit A" H
barometric pressure (baro) sensor performance MHC
"left front wheel speed sensor circuit" M
"right front wheel speed sensor circuit" M
not sure if I missed something in the tune with these or what.. thanks AGAIN
MuscleTruck03
Mar 10, 2010
369
north ogden, ut
ok guys sorry for all the noob questions but what would make it so my #2 tune is actually #3 on the switch and #3 is where #4 and so on and the #5 isnt a dead pedal anymore? its like #2 on jumped a place forward
