Need some advice on tires for pulling
13,714
776
I think I will be participating in a sled pull in a couple of weeks, and I was hoping some of you regular sled pullers could give me a little advice on what tires to use. I have a couple of options, and I'm not 100% sure which way to go. Option 1 is to use a set of 285/70-17 Firestone Destination M/Ts. Two of them are probably 50% tread, and the other two are probably 25%. Option 2 is to use a set of 305/50-20 Nitto NT420Ss. They are brand new with less than 5000 miles on them. Both tires are pretty close in size. The Firestone is a little bit taller, and the Nitto is a little bit wider. Here is a picture of both to show the tread pattern.
MD-Dmax
Jan 6, 2010
318
I can see them both now, I am no pullerbut the destination tires look more aggressive then the nitto's. I guess alot of it plays in track condition to
bubba2400
Jul 19, 2009
199
Union Grove, WI
Can I choose neither? Probably a horse a piece. If it is a good sticky clay track it won't matter which ones you use they will hook if you weigh 8000lbs. If it is a sandy loose track neither will hook so it won't matter.
Go with the M/T's.
13,714
776
By that logic, I'll just stick with the Nittos. They're already on the truck, and since it doesn't sound like it matters, I'll just save myself the hassle.
bubba2400
Jul 19, 2009
199
Union Grove, WI
Yes, that usually becomes the deciding factor, which is easier!!! I know how that goes. Good luck at the pull.:thumb: I think you will do fine.
13,714
776
Well, I have some info on the track and the sled. Here's what Gene posted on CompD:
Sled Is Bungarts Ex factor out of MO. TRack is plenty wet, but supports the sled, we'll dry it some in the moring then add water back in. Seems to be black gumbo with a smattering of red clay. Wayyyy better than Crandall or the old DHRA track in Baytown.
Fine Kubota tractors with the local dealershisps support.
Bungarts scraper has a water tank on it for maintence.
Now I'm really thinking I should run the Firestones. If that black dirt is even a little wet, it gets super slick. Does anyone know anything about the sled they brought in? New thoughts on tires?
juddski88
Freedom Diesel
Jul 1, 2008
4,656
120
Chesterfield, Mass.
Fierce Attitude M/T's get my vote! they are almost an exact copy of an MTZ but wayyy cheaper. I got a whole set of 305's mounted on 16's for $745 out the door.
13,714
776
I was really trying to decide between the two sets I have already, but thanks for the info. I'll keep them in mind next time I go tire shopping.
13,714
776
I may actually know someone who has some of those tires I could borrow. I'll have to talk to him tomorrow morning.
