Need powerstroke help
dmaxfireman
'Can do' kind of guy
Apr 8, 2007
2,329
CT
Have a friend with a 98 f350 i think it popped a piston. ton of blowby out the oil fill. has 275k miles.
what year range can i get a motor from to swap into his truck? anybody have a good motor they are getting rid of?
thanks everybody :)
maxaholic
1,876
40
Central, Texas
I think as long as it's a 7.3 powerstroke that everything will work. Just don't get one with the pmr rods. And you might have to do some sensor swapping if it's from a newer one. And the reason I say this is I had a buddy with a '03 that he blew up. His replacement motor came from a '97 I believe.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
hmm the sticker on the door is early month 98? but it is a nbs so prob a 99 then?
If it is a eraly 99 then he can use the 99-03 7.3L I believe, but he will need to re-use his injectors as early 99's used a different injector than any of the others. Also the turbo on the early 7.3L is unique to it as well, but I believe the later turbo will work just as well for stock HP levels(7.3 turbos don't take well to more than a 60-80HP tune).
maxaholic
1,876
40
Central, Texas
This is a text a powerstroke buddy just sent me. Notice I said text as in text message with bad grammar and punctuation.
94-early 03s will all bolt in jus have to swap accesories an motor mounts if comes from obs, if get a late 99up id try get it complete with turbo. Some late 01s had pmrs like the 02 03s have. Easy to check for pmrs they have bolts on the rods where forged have studs.
Edit: He just sent this one also.
If put older one they will need to upgrade injectors, if go newer they need to get pcm from newer truck
dmaxfireman
Apr 8, 2007
2,329
CT
thanks guys :hug:
think we found one out af a same year e350 van, gonna go take a look at it later this week.
