Damn thats right in my price range. I just feel like besides all the little problems that may/will arise running 50-70psi of boost is gonna take its toll in the long run. Does it make sense to run twins at around 45 psi or does a single make more sense. Im more concerned with long term reliablity than huge power numbers. MY last two trucks have had a ton of mods and something was always messing up.
Its only cheap if you have all the proper tools and the ability to fab everything up. I spent like 22 hours over two days building mine and I had 2 of my friends helping me a bit. If I wouldnt have had someone to help hold things and such it would have probably taken over 30 hours.
So far ive only hit 47psi and thats with all the fuel i can throw at it with just a lift pump without dropping rail pressure. It might make a little more with some tweaking to the tune and higher shift points but im not sure. Theres always going to be a risk of breaking something. I have a spare short block in my garage for just that reason.
Ive never driven or ridden in a duramax with a big single but ive driven a dodge with one and in my experience i prefer twins for street use. A big single can be fun but it can kinda suck to drive at times.
As for long term reliability your probably kinda screwed. It seems like when you push 500rwhp or more your on borrowed time and some people just have better luck than others. It seems like there are some things you can do or have products and services from certain people that have a good success rate to help with reliability but you still never know. And if you use the power on tap all the time something is gonna give.
