I'd like to run the heck out of an llm on the engine dyno but need a manual transmission version. Thanks for your help
Running an LMM on the engine dyno. No transmission connected.
No kidding, son of a gun..... What about the 3500 4500 and 5500's.
What was GM thinking?
Call Dan at PPE about getting a standalone harness.
I have Manual trans stuff for everything but the LMM.
Never offered AFAIK.
Ross has suggested trying to run it without a trans connected - not sure if it will work or not, worst case scenario is that you'll get a bunch of codes and it won't run. However the codes that may show up may indicate what needs to be done to fix it.
Cheers
Cindy
Thanks Cindy
I'm committed with this engine. I'll have to test run no matter what, money has been spent. If I could follow up with result to you, I'd appreciate your help. Tomorrow the fun begins. Thank you.
Rather not, 6 hole injector engine. But, just might try it with injector change? But really, I don't have a clue.
I recently posted an LB7 running on a stand with a TCM hooked up and no tranny. I think this can be done. The gentlemen had modified the harness(es) himself to make it a "stand alone" harness.
I'd imagine similar things can be done with any version of the DMax and for doing this quickly, without knowing how to yourself, I'd suggest getting in touch with PPE.
C-ya
