Need hypertech/efi cant do
TOMAN
81
How do you set the speed on this truck,I have reset the ECM/TCM no help,he has 285/75/16 and is 5 mph off ? Have EFI ?
__________________
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Find out the percentage it is off. Add or subtract that percent from the current reading, be it dia, rev/mile, etc. This works for all tuners that can adjust the speedo, and all types of vehicles.
Are you using EFILive or HyperTech?
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Example: If you are off 5 mph at 50mph (actual = 55, speedo = 50), 5/50 = .1 = 10%.
If it goes by tire dia, say 33 inches, you multiply 33 x .1 = 3.3. Add 33 + 3.3 = 36.3.
If it's rev's per mile, say 600, then 600*.1 = 60. In this case, you go backwards, subtract 600 - 60, and type in 540.
Check it with a GPS and fine tune.
AS I REMEMBER... If I'm wrong, someone should step in. My math sucks lately. :D
TOMAN
81
find out the percentage it is off. Add or subtract that percent from the current reading, be it dia, rev/mile, etc. This works for all tuners that can adjust the speedo, and all types of vehicles.
Are you using efilive or hypertech?
efi
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
It goes by tire dia on LB7/LLY. It goes by revs per mile if you are LBZ+.
There is a Speedo section to your left on the screen.
I don't do a lot speedo correction lately, so my memory is poor. I only tune my own stuff now.
TOMAN
81
No help changed tires to 33.5 and tire rpm from 370 to 333 still 5 mph off ?
TOMAN
81
changed it all,put in 37" tires 5 mph off :confused: truck is going 75 speedo at 70 WTF
bradyn
Sep 22, 2010
kansas
Click on the speedometer + sign, then select parameters. Then go to speedo calculator. Then select speedo fine tuning put in the mph differences and it will give you a new number, select apply then load it to the truck. Mine did the same thing.
