LB7: Need help.
Kappa9012
MAN.... I Broke it again.
Aug 5, 2008
694
Peoria Il
Ok guys, i've got a few questions.
I'll start with the easy one first. Why do the balance rates go to zero once vehicle speed is registered?
Next, and for the real question... LB7 has an intermittent rough idle, so I logged the balance rates, cylinder #1 is holding a pretty constant 5.75 to 6, so #1 i am pretty confident it's bad, but it does that even with a smooth or rough idle. Here's the catch, when the idle does go rough nearly 4 other injectors start to go outside of "Spec".
It's random when the idle acts up, part load and full throttle the truck runs perfect.
Could this be a ficm harness problem????
Any ideas? Truck has roughly 50,000 miles on it.
TeaBagger2006
Im a Garrett Nut Swinger
May 11, 2008
3,123
15
Bis ND
x2 on the fpr
i think they go to zero because the flow will vary when you accelerate where as at idle its steady constant pressure from the cp3. im not sure on that....i did know but forgot
