<TABLE width="95%"><TBODY><TR><TD>
07099A — SPECIAL COVERAGE ADJUSTMENT –FUEL TANK INLET CHECK VALVE FRACTURE</TD></TR></TBODY></TABLE>
<TABLE width="95%"><TBODY><TR><TD width="7%">Models:</TD><TD>2002-2004 CHEVROLET TRAILBLAZER EXT</TD></TR></TBODY></TABLE>
<TABLE width="95%"><TBODY><TR><TD width="7%"></TD><TD>2002-2004 GMC ENVOY XL</TD></TR></TBODY></TABLE>
<TABLE width="95%"><TBODY><TR><TD width="7%"></TD><TD>2004 GMC ENVOY XUV</TD></TR></TBODY></TABLE>
<HR>
This bulletin cotains a revised service procedure and claim information. Discard all copies of bulletin 07099, dated June 2007.
<HR><A href="http://gsi.xw.gm.com/newsi/showDoc.do?docSyskey=2005993&from=bcpi#N65563">
Condition
Some customers of 2002-2004 Chevrolet TrailBlazer EXT and GMC Envoy XL, and 2004 GMC Envoy XUV vehicles may comment on an SES light illumination, which may be accompanied by a fuel odor, and/or a few drops of fuel on the ground when refueling the vehicle. This may be caused by a fracture of a weld on the fuel tank inlet check valve (ICV). The ICV is located above the full fuel level. A fracture in this area may allow fuel vapors to pass through and allow droplets of fuel to accumulate on the side of the fuel tank as it passes over the fracture during refueling.
<A href="http://gsi.xw.gm.com/newsi/showDoc.do?docSyskey=2005993&from=bcpi#N65572">
Special Coverage Adjustment
This special coverage covers the condition described above for a period of 10 years or 150,000 miles (240,000 km), whichever occurs first, from the date the vehicle was originally placed in service, regardless of ownership. The repairs will be made at no charge to the customer.
For vehicles covered by Vehicle Service Contracts, all eligible claims with repair orders on or after June 8, 2007, are covered by this special coverage and must be submitted using the labor operation codes provided with this bulletin. Claims with repair orders prior to June 8, 2007, must be submitted to the Service Contract provider.
<A href="http://gsi.xw.gm.com/newsi/showDoc.do?docSyskey=2005993&from=bcpi#N65584">
Vehicles Involved
Involved are
certain 2002-2004 Chevrolet TrailBlazer EXT and GMC Envoy XL, and 2004 GMC Envoy XUV vehicles built within the following VIN breakpoints:
<TABLE border=0 width="100%" align=center><TBODY><TR><TD><TABLE border=1 width="95%" align=left><TBODY><TR><TH vAlign=bottom align=center>
</TH><TH vAlign=bottom align=center>
Division
From
Through
</TH></TR><TR height=50 vAlign=middle><TD vAlign=middle rowSpan=2 align=center>
</TD><TD vAlign=middle rowSpan=2 align=center>
TrailBlazer EXT
</TD><TD vAlign=middle align=center>
22442652
22460353
</TD></TR><TR height=50 vAlign=middle><TD vAlign=middle align=center>
26100010
26138714
</TD></TR><TR height=50 vAlign=middle><TD vAlign=middle rowSpan=2 align=center>
TrailBlazer EXT
32100002
32229743
36100001
36246835
TrailBlazer EXT
46100116
46119631
Envoy XL
22437217
22460354
26100018
26138713
Envoy XL
32100013
32191834
36100011
36246828
Envoy XL
46100127
46119624
Envoy XUV
46100001
46116824
</TD></TR></TBODY></TABLE></TD></TR><TR><TD></TD></TR></TBODY></TABLE><A href="http://gsi.xw.gm.com/newsi/showDoc.do?docSyskey=2005993&from=bcpi#N66156">
Parts Information
Parts required to complete this special coverage are to be obtained from General Motors Service and Parts Operations (GMSPO).
Part Number
Description
Qty/ Vehicle
</TH></TR><TR height=50 vAlign=middle><TD vAlign=middle align=center>
15229310
Tank, Fuel
15034832
Seal, Fuel Sdr (O Ring)
</TD></TR></TBODY></TABLE></TD></TR><TR><TD></TD></TR></TBODY></TABLE><A href="http://gsi.xw.gm.com/newsi/showDoc.do?docSyskey=2005993&from=bcpi#N66299">
Customer Notification
General Motors will notify customers of this special coverage on their vehicles (see copy of typical customer letter included with this bulletin - actual divisional letter may vary slightly).
<A href="http://gsi.xw.gm.com/newsi/showDoc.do?docSyskey=2005993&from=bcpi#N66308">
Service Procedure
<TABLE width="98%" align=center><TBODY><TR><TD vAlign=top width=15 align=left>1. </TD><TD vAlign=top>Inspect the fuel tank for a leak at the fuel tank inlet check valve (ICV). Refer to Fuel Tank Leak Test in the Diagnostic Information and Procedures section of SI, if required.</TD></TR></TBODY></TABLE>
<TABLE width="95%" align=center><TBODY><TR><TD vAlign=top width=1 align=right>• </TD><TD vAlign=top>If a fuel leak is present at the fuel tank ICV, replace the fuel tank. Proceed to Step 2.</TD></TR></TBODY></TABLE>
<TABLE width="95%" align=center><TBODY><TR><TD vAlign=top width=1 align=right>• </TD><TD vAlign=top>If no fuel leak is present at the fuel tank ICV, no further action is required.</TD></TR></TBODY></TABLE>
<TABLE width="98%" align=center><TBODY><TR><TD vAlign=top width=15 align=left>2. </TD><TD vAlign=top>Replace the fuel tank. Refer to the appropriate service procedure in SI.</TD></TR></TBODY></TABLE>
<A href="http://gsi.xw.gm.com/newsi/showDoc.do?docSyskey=2005993&from=bcpi#N66346">
Claim Information
For vehicles repaired under the terms of this special coverage, submit a claim with the information indicated below:
Repair Performed
Part Count
Part No.
Parts Allow
CC-FC
Labor Op
Labor Hours
Net Item
</TH></TR><TR height=50 vAlign=middle><TD vAlign=middle align=left>
Inspect Fuel Tank – No ICV Fracture Found
N/A
N/A
N/A
MK-95
T5676
0.3
N/A
</TD></TR><TR height=50 vAlign=middle><TD vAlign=middle>
Inspect and Replace Fuel Tank
MK-95
T5663
2.3
N/A
</TD></TR><TR height=50 vAlign=middle><TD vAlign=middle align=left>
Customer Reimbursement (Canadian & Export Deaers/US CAC)
N/A
N/A
N/A
MK-95
T5664
0.2
</TD></TR><TR height=50 vAlign=middle><TD vAlign=middle colSpan=8 align=left>
* The "Parts Allowance" should be the sum total of the current GMSPO Dealer net price plus applicable Mark-Up or Landed Cost Mark-Up (for Export) for the fuel tank needed to complete the repair.
** The amount identified in the “Net Item” column should represent the customer reimbursement amount.
</TD></TR></TBODY></TABLE></TD></TR><TR><TD></TD></TR></TBODY></TABLE><A href="http://gsi.xw.gm.com/newsi/showDoc.do?docSyskey=2005993&from=bcpi#N66759">
Customer Reimbursement – For US
All customer requests for reimbursement for previous repairs for the special coverage condition will be handled by the Customer Assistance Center, not by dealers.
A General Motors Customer Reimbursement Procedure and Claim Form is included with the customer letter.
Important: Refer to the GM Service Policies and Procedures Manual, section 6.1.12, for specific procedures regarding customer reimbursement and the form.
<A href="http://gsi.xw.gm.com/newsi/showDoc.do?docSyskey=2005993&from=bcpi#N66780">
Customer Reimbursement – For Canada and Export
Customer requests for reimbursement of previously paid repairs to correct the condition described in this bulletin are to be submitted to the dealer prior to or by June 30, 2008. Repairs must have occurred within the 10 years of the date the vehicle was originally placed in service, or 240,000 km, whichever occurs first.
When a customer requests reimbursement, they must provide the following:
<TABLE width="100%" align=center><TBODY><TR><TD vAlign=top width=40 align=left></TD><TD vAlign=top width=10 align=left>- </TD><TD>Proof of ownership at time of repair.</TD></TR></TBODY></TABLE>
<TABLE width="100%" align=center><TBODY><TR><TD vAlign=top width=40 align=left></TD><TD vAlign=top width=10 align=left>- </TD><TD>Original paid receipt confirming the amount of unreimbursed repair expense(s) (including Service Contract deductibles), a description of the repair, and the person or entity performing the repair.</TD></TR></TBODY></TABLE>
If the work was done by someone other than a GM dealership, the amount of reimbursement will be limited to the amount that the repair would have cost GM to have it completed by a GM dealership.
June 2007
Dear General Motors Customer:
As the owner of a 2002, 2003, or 2004 model year Chevrolet TrailBlazer EXT or GMC Envoy XL, or 2004 model year GMC Envoy XUV, your satisfaction with our product is very important to us.
This letter is intended to make you aware that some 2002, 2003, and 2004 model year Chevrolet TrailBlazer EXT and GMC Envoy XL, and 2004 model year GMC Envoy XUV vehicles may have a condition where the Service Engine Soon (SES) light may illuminate, which may be accompanied with a fuel odor, and/or a few drops of fuel may fall on the ground when refueling the vehicle. This may be caused by a fracture of a weld on the fuel tank inlet check valve (ICV). The fuel tank ICV is located above the full fuel level. A fracture in this area may allow fuel vapors to pass through and allow droplets of fuel to accumulate on the side of the fuel tank as it passes over the fracture during refueling.
SES light activation does not necessarily indicate a condition due to the fuel tank ICV fracture. Except when SES light activation is accompanied by the additional conditions mentioned (i.e., fuel odor and/or a few drops of fuel on the ground during refueling), please consult your Owner’s Manual.
Do not take your vehicle to your GM dealer as a result of this letter unless you believe that your vehicle has the condition as described above.
What We Have Done: General Motors is providing owners with additional protection for the fuel tank ICV. If this condition occurs on your 2002, 2003, or 2004 model year Chevrolet TrailBlazer EXT or GMC Envoy XL, or 2004 model year GMC Envoy XUV within 10 years of the date your vehicle was originally placed in service or 150,000 miles (240,000 km), whichever occurs first, the condition will be repaired for you at
no charge.
What You Should Do: Repairs and adjustments qualifying under this special coverage must be performed by a General Motors dealer. You may want to call the service department at your dealer to find out how long they will need to have your vehicle so that you may schedule the appointment at a time that is convenient for you. This will also allow your dealer to order parts if they are not already in stock. Keep this letter with your other important glove box literature for future reference.
Reimbursement: The enclosed form explains what reimbursement is available and how to request reimbursement if you have paid for repairs for the special coverage condition.
If you have any questions or need any assistance, just contact your dealer or the appropriate Customer Assistance Center between the hours of 8:00 AM and 11:00 PM, EST, Monday through Friday. They can be reached at the number listed below.
Division
Number
Text Telephones (TTY)
1-800-630-2438
1-800-833-2438
1-866-996-9463
1-800-462-8583
Guam
1-671-648-8650
Puerto Rico – English
1-800-496-9992
Puerto Rico – Español
1-800-496-9993
Virgin Islands
1-800-496-9994
We are sorry for any inconvenience you may experience; however we have taken this action in the interest of your continued satisfaction with our products.
Scott Lawson
General Director,
Customer and Relationship Services
Enclosure
07099
<TABLE width="95%"><TBODY><TR><TD width="80%" align=left>GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
</TD><TD width=42 align=center>
</TD><TD width=167 align=center>WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2011 General Motors. All rights reserved.
Looks like it only covers the long wheelbase models. Check to see if your vin is in the breakpoints in this recall.
