I have Speedhut boost, EGT, and fuel gauges in my truck and I would like the back lighting to dim with my cluster better. The problem is they are just to bright at night. I have to turn my dimmer 1/2 way down before the speedhuts start to dim at all. My old gauges with LEDs worked perfect the way I had them wired. This is from Speedhuts site.
"The dial lighting is accomplished via an electroluminescence panel behind the dial. This panel glows when it is subject to around 200 volts AC. The DC to AC inverter takes 12 volts DC and creates the needed 200 volts AC to power the dial lighting."
I'm wondering if I can install a resistor to get them to dim with the factory lights better. I'm just not sure how big of resistor to use and if that will even work because of the inverter.
