Need help with 4x4 problem
05chevy
1,086
Hey guys I went racing yesterday and on the third pass when I took off I heard a loud bang. I got off the track checked everything out and it looked fine. Went to run again and 4x4 wouldn't work. When I went to load on the trailer I put it in 4lo you can hear a clicking noise coming from the front. You can also crab the front drive shaft and it probably has 2" of play at the transfer case. Can any one help. Do you think its my front axle or transfer case? And you can hear the transfer case ingauge when I push the button.
Tank222
Feb 17, 2010
337
Frederick,MD
Most likely the shift fork and the shift for slide mechanism. Take the actuator off and see if you can engage it manually.
13,637
678
How is the play? Front to back, side to side, or rotational?
