In the last week or so my truck has been acting differently. I'll do my best to explain. This started after temperatures here got into the 20's and lower, but that may be coincidence.
Normally when I'm driving 65-70 mph on the highway, I will see 2-3 psi on my CTS. And if I come to a hill and/or ease into the throttle, boost will increase in a somewhat linear manner according to my throttle input.
Now, intermittently, I'll see 0 psi as high as 85 mph (haven't tried faster). When doing this, I have several times eased into the throttle and still see 0 psi, then a few seconds later BAM, I have 14+ psi. When the truck acts up, this is repeatable 3 or 4 times. If I romp on it, I see 21 or 22 psi, which is the max reading for the CTS as far as I know.
My thoughts are that my MAP sensor is crapping out, or my wastegate is sticking. I'm not sure how to test for these, because when datalogging the MAP, it should show zero psi if the WG is stuck, right?
Or maybe I'm completely missing something else. I don't know what's common that might cause this issue, so thanks in advance for your help.
