Need help problems after cp3 install
Bbuchanan11
319
178
Sarver, PA
Just put a new cp3 on my truck started up fine after cranking for a few seconds but the check engine light came on oil pressure gauge will not move and the fuel gauge also will not move throws a bunch of codes for oil pressure fuel level senser a/c mass air flow senser and maybe more can't think of them right now... Checked all of the connections atleast 3 times checked all the fuses.. Can get both gauges to move with a scanner. I am lost and I doubt anyone else has run in to this before.... Thanks
Bikey
Corvette Racer
Mar 18, 2013
17
Brooklyn
I had an odd issue with the oil pressure gauge not working after a CP3 & injector & water pump swap - there was continuity in the wires etc. Turned out to be a bent pin in one of the big connectors. They are not exactly the best design (long, unsupported pin). Take a look inside the connector and make sure they are all straight.
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
Check the wires
Check the wires that go behind the bracket on the drivers side. It sounds like you pinched some wires that run down to the connectors on that side of the motor.
Bbuchanan11
319
178
Sarver, PA
Sting puller that is exactly what happened... Pulled the bracket off and found the wire pinched... Truck was missing real bad lastnight and now everything is perfect thanks guys!
