02 lb7. Built trans. Efi live. 240k. 6 inch lift. 37s.
When I'm slowing down for a stop sign or to turn and my truck goes to shift from 2nd to 1st it will randomly slam into first and the abs will engage. Also when truck has sat overnight and the colder the worse it is. When you first shift into drive, won't do it into reverse it will slam into gear. But after that it's fine. Trucks shifts and drives great beside those two issues. So far fluid and filters have been changed. No codes. Checked all wheel speed sensors and connections. Cleaned grounds. Data streamed wheel speed with no issues. Changed ect sensor. I'm at a loss. Shop that did trans 15k ago keeps saying its electrical outside of the trans. Or it has adaptation issues and needs wired for constant power. Please help! The harsh down shift is scary when towing. Also all new u joints and greased splines
