need help crank but no start
markd113
Feb 17, 2016
9
i have a 2001 lb7 2wd truck, that i just put 30 over nozzles on new head gaskets and studs, all new gaskets and lots of new parts including a custom made s475 over stock, i just finished everything last week and boom it cranks and wont start, fuel system is bled but i was throwing a cam sensor code, so i replaced the sensor and still no good, checked all wiring and its good did all electrical tests that i know of, so i had my local efi live guy come take a look and he saw there is no rpm, also he said there was loss of data link, so basically i have no idea what is up with this truck, checked the grounds and everything multiple times, and also had the security feature tuned out, im at a loss on what to do and cannot afford to take the truck anywhere, someone please help
markd113
Feb 17, 2016
9
checked that, they are not switched, i know the plugs are the same so i made sure of that right away
markd113
Feb 17, 2016
9
It has the cam and crank sensor codes but I replaced the sensors with oem ones and I don't think it's the fuel system because it's not picking up rpms
markd113
Feb 17, 2016
9
BUMP!!!! about to pull the motor out and put a 12 valve in it!!!! which i do not want to do
markd113
Feb 17, 2016
9
It will turn over until the battery dies and it has enough pressure that it should be starting
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Pull the crank sensor and see if you can wobble the tone wheel? Ohm position sensor wires all the way. Maybe the bale connector has a bent pin or something
markd113
Feb 17, 2016
9
Ive honestly tried all of that good stuff, could a bad Tcm have anything to due with this issue
3,733
305
If the TCM is shorting out the CAN bus, it could cause some serious problems. Try unplugging it and see if it starts.
If the ECU or FICM don't see RPM, it can't figure out when to fire the injectors, so it won't. Since it was reporting 0 RPM and a cam sensor earlier, I would quadruple-check the cam and crank sensor wires. I'd also stick a scope on the sensor outputs and make sure they are sending out valid data.
markd113
Feb 17, 2016
9
I know the wiring is right I have fully checked it multiple times, I have yet to check the out puts though, I will try to in plug the Tcm and check them, just sucks it's been sitting for months and I can't figure anything out
3,733
305
Electrical problems always suck because they require special tools to diagnose.
If you live within a couple hours of Boise, Idaho, I would be willing to drive out with my scope and check it out this weekend. Or see if you can find someone local with a scope who is willing to check it out.
