Need fuel system advice
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
i have the truck tore down getting ready to install my twins and had to tear it down pretty far to get the y bridge out while its this far down i was going to do a lbz reg. and port the rail fittings are there any other easy cheap mods to do before it goes back together and are the rail fitting mods and lbz reg worth the time .
thanks Trent
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Technically you are not drilling out the fitting but more the piece behind it on the LB7 Correct? There is a little doghnut shape piece that is more restrictive....Atleast mine was.
I also welded the pop valve shut because it was in the way of my Y bridge.
As far as low pressure lines, I removed all stock lines and started over...Mostly do to bordom:D
TrentNell
Jul 7, 2008
7,543
slc tuah
dont have the fitting off yet so i'm not sure thats why i'm asking the experts :angel: , and havent seen the new y bridge yet i am just getting it torn down to try to save some time on the install when i get the parts . any other mods i should do while its tore down ?
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
attachment.php
attachment.php
On the left Trent is what you want to drill out ( the doghnut:D). I am not saying it will help it's just what I did:) Do both rails.
The LLY has a different style 1 piece fitting that is a complete orfice and that is why you drill the fitting I went to 60 thousandths" IIRC
TrentNell
Jul 7, 2008
7,543
slc tuah
attachment.php
attachment.php
wich one on the left :confused: i planned on doing both rails did you do both the same ? 60/1000
ripmf666
15,123
14
47
Wentzville Mo
What bridge are you getting?If it's the LBZ one like PPE sells you have to change your manifolds also to work.
TrentNell
Jul 7, 2008
7,543
slc tuah
Nathan is moding one that will come with my twin kit . not sure what it looks like yet . i am assuming its a stocker with a bigger pipe welded into it .
ripmf666
15,123
14
47
Wentzville Mo
cool was not sure if it was something you were changing lol.better safe then sorry to find at the last min and hold you up on install.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
The only one:D on the right is the fuel rail fitting. And the left is what you drill out.Above is the rail.
When you pull out the rail fitting you can use a magnet to get the other piece out ( the left )
Yes do both rails:)
TrentNell
Jul 7, 2008
7,543
slc tuah
Yes do both rails:)
having not taken it apart yet it did not make sence thanks for the dummy explanation :hug:
and henry thanks for the heads up on the y bridge i apiciate you guys help :)
TrentNell
Jul 7, 2008
7,543
slc tuah
Are you going to drill out the fitting on the cp3 also?
if you tell me how i will :D , just kidding if it can be done with out pulling the cp3 i will i am sure it can . i am interested in doing every free or cheap fuel mod you can think of , i might do your mod to the gear pump also if i have the time .i need all the fuel i can get with these twins .i got my new hellman gravity feed pick up on friday and the sotp meter says it was a good mod i need to log some runs after reassembly and see what kind of gain i made with holding rail pressure after all these mods .
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Should be able to get the fitting out,Carefull you dont get crap in any of the line while disconnected.
Thats pretty much every thing i can think of:)
