anyone know where i can get a downpipe and IC pipe that will work with an s472.
Dirtymaxx03 Active member Aug 4, 2009 3,109 1 38 May 22, 2011 #1 anyone know where i can get a downpipe and IC pipe that will work with an s472.
ChevyDieselLLY Whats A Budget??? Apr 1, 2008 2,684 1 0 38 MI, NC, now Hawaii May 22, 2011 #3 Call Trent
Drholliday Member May 28, 2008 286 0 16 Gresham, OR May 23, 2011 #4 ATS down pipe works great. For the IC pipe you can use any one of the 3" ones on the market. You just need to cut it and use a silicone boot to make it taller. (you can do it with the stock one too, but then its only 2.5")
ripmf666 Active member Sep 20, 2006 15,123 14 38 47 Wentzville Mo May 23, 2011 #5 So this intercooler pipe might even work since you wanted v band and it is 2 part. Charge Pipe (S2), Turbo To Intercooler, Aurora 5000 single GM 6.6L Duramax (bead roll both ends, longer of 2 pipes, 3 bends)
seth999 Wheeewwwww!!! Jul 1, 2009 439 0 0 Corbin,KY May 23, 2011 #6 That should work :thumb: ATS was high $$$ last time I checked...maby Henry can work something out
ripmf666 Active member Sep 20, 2006 15,123 14 38 47 Wentzville Mo May 23, 2011 #7 Yea work something out since we already talked about the dp.
Dirtymaxx03 Active member Aug 4, 2009 3,109 1 38 May 23, 2011 #8 Henry, so thats a charge pipe for a a5000? can you pm me a price on that if you can get it? thanks
ripmf666 Active member Sep 20, 2006 15,123 14 38 47 Wentzville Mo May 23, 2011 #9 Dirtymaxx03 said: Henry, so thats a charge pipe for a a5000? can you pm me a price on that if you can get it? thanks Click to expand... Pm sent and yes the A5 and A6 http://www.duramaxdiesels.com/forum/showthread.php?t=27704
SSchmi5519 LLY Cult Leader Oct 19, 2008 3,387 1 36 Arizona May 23, 2011 #10 Both the ATS downpipe and intercooler tube will fit the S400s with NO modifications.
