I am going to be changing the setup of my truck. I am going to twin my 66 with an 81. I am leaning towards a 1055 converter. will this be too loose? I am open to suggestions other than the 1058. thanks
Kely
Kely
Mike would know better Kelly,But If you are twinning I wouldnt think you would need it JMHO WHy not try the one you have now first with the new twin setup
Not familiar with the turbos. How hard will it be to spool? The 1055 is great for big singles.
A 1057 should not be "too tight" for a 66mm charger. We can spool a 75mm charger with one.
But Mike got us a looser converter for the 80mm charger, and it works great. Whatever is in Casper now is good for big chargers.
by 75mm do you mean a 42? Is 1800rpm stall really enough to light that thing?
How does one get past the hump at 1800 rpms?
Kely
I have a 1057 that is too tight for the 66 right now. after it is twinned it would get worse i would think.
i am going to have a twin kit very close to what you have stated .The turbo on my truck is an S300 66/74. It spools ok most of the time but depending on the DA (We are at 2300ft.) it can be a bit hard. The 81 mm is similar to an S480.
i started out with a 1054 stall of 2000 rpm it was way to tight even for my at the time bd supermax , i always had troubles spooling everyone said it could not be to tight for that turbo but with a d/a of 6000 ft it was just to tight i am now running
the 1055 and i love it night and day difference the turbo spools twice as fast i could barely power brake before ( it took 6-8 sec to get enough boost to break the tires )but now if i want the tires are spinning within a sec or two , go with the 1055 you wont be sorry it tows well also . just my own experience something to add i did the high flow feed pipes also and it helped spooling as well .
