Need advise on egr delete
bigjohn
GMC Dmax
Oct 13, 2012
408
Westview Pa
I've been looking at the delete pipes for the egr and I'm not sure what's the best fit. Is there a company that you guys recommend. And if I decide to put it on will It mess with the computer that's the only thing that I'm sure about or should I have a shop put it on what do you think that it will cost. Don't have a EFI live. Not interested in makin major horse power just looking for longevity of the engine can't be good recycling exhaust through the motor. And I already clean the the intake pipe and the egr valve out don't want to keep doing that every so often. Any info would help thanks.
ikeG
Oughta Know Better
Apr 19, 2011
2,464
147
Western PA
www.facebook.com
Profab gets my vote, just installed his delete on my dually. Fit like a glove.
Get your egr deleted, reroute the pcv and you have yourself a good reliable LBZ.
you will need programming of some sort, though.
countrycorey
Trust Me I'm an Engineer
Jan 30, 2010
1,512
35
LA
There are several good kits from the vendors here. Allseason, HSP, ProFab all have good kits and you will need some tuning to turn off the CEL codes.
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
I vote for All seasons/ DHD.
PERFECT FIT!!! And tons of options available for any build level or build goals!
Yes if you delete the EGR you will incur a engine light on the dash, you can get tuning that will just turn off the EGR sensor or complete tuning that will provide more power and have the EGR sensor turned off
Or you can deal with the light.
I suggest doing some forum searching about it, both tuning, the types of EGR "deletes" available and why you would want to use one way over another...
It sounds like an EGR blocker plate might be the best option for you, along with some tuning...
Happy hunting:hug:
xtremebikr04
Jan 17, 2011
573
Vermont
id give any of the vendors here a call. profab, dhd, hsp all make kits. If you want/don't mind the egr stuff staying in the engine bay then get a blocker plate.
indiana_jones
LargeFarva
Dec 3, 2013
341
Ft Collins Colorado
TOTAL NEWB QUESTION:
I have the EGR CEL on. My banks scanner is telling me about it too. Im wondering how can I tell if I even have the EGR anymore. Guy before me coulda taken it off. My mechanic says the code generally means the EGR valve needs to be "cleaned".
TLyons90
Apr 22, 2013
1,631
Greenville, SC
My vote is HSP! Before finding out about them I did the cold pipe from SDP for the EGR delete and have no complaints what so ever! Also of you want longevity I highly recommend going to EFI and getting some basic custom tunes for what you have done!
TLyons90
Apr 22, 2013
1,631
Greenville, SC
I believe the EGR valve needs to be in place and functional for the fingerstick to work properly.
X2, I only think the finger stick works with blocking the egr. You also have to turn off the butterfly valve in the bottom front where the EGR delete pipe goes in which can only be turned off with EFI
LWATSON
future trans limpers
Jul 30, 2008
2,587
55
Scotland Neck NC
Why not just install a blocker plate? IMO theres really no advantage to a delete unless your serious about making power. The blocker plate is cheap and easy to install, you will still need tuning or a fingers stick regardless.
9,903
149
To the OP this is what I would do unless you want to remove the egr.
Easiest way to go and likely the cheapest.
Long story short when I went to delete my EGR, end result was a new turbo, previously enjoyed p/s exhaust manifold, and alot of swearing!!!
