need advice/ 05lly w/ blow by an high oil psi
Fastorange
Jan 31, 2009
256
ohio
Im a bit stumped on this one. the head gaskets were replaced before last winter and drove fine no issues... when the nice weather started this year I parked my truck for a month and started driving my car... so the other day I needed to use my truck. it starts fine and drives fine.. but oil psi is at 50 at idle and 75 under normal driving..
my first thought was the cluster might be messed up.... checked it with efi.. and its reading the same... drove to the shop and popped the oil fill cap and yup blow by... I am going to do a compression test today and try to cut out injectors to see if there is any change at idle... truck drives fine... I have been working on my other truck, its like this one gets jealous and wants attention too.. I'm hoping its not a bad piston.. is there anything I might be over looking?
ALLY Fox
Old Man Truck
Dec 14, 2010
434
Oregon 7S5
Do you have PCV rerouted? Check and make sure nothing's plugging the vent hose. Maybe some critter has made a nest in the tube while your truck was parked?
Fastorange
Jan 31, 2009
256
ohio
yes the pcv is rerouted.. im going to check that today... I noticed the oil cooler was leaking to..
Fastorange
Jan 31, 2009
256
ohio
ran some marvel mystery oil in the crank case for about 50 miles, changed oil and sensor, when I removed the sensor nasty slug came out... oil pressure is back to normal
