National/BCA Wheel Bearing
Sep 10, 2008
1,072
Morehead City, North Carolina
Are National/BCA wheel bearings good quality? How do they compare to Timken? I realize most here rave Timken; however, I can get a competitive price and lifetime warranty with National/BCA.
http://www.carquest.com/webapp/wcs/...ional__10151_-1_10651_381439_32225?acesApp=1#
I tried the cheap wheel bearing route once, now I'm replacing a unit not even 10,000 miles later.
Also, is there a trick to removing those 4x 15mm bolts? I started to round one yesterday with breaker bar and quit. They were soaked in PB Blaster too....
Thanks,
jdlover1
437 Cubic Inches
Oct 4, 2006
538
chapanoke,nc
carquest is the only place other than the dealership i deal with. I have had good luck with the cheaper wheel bearing from them. I usually turn the wheel either way so i can get a 3/8s impact in there to take the 4 bolts out that hold it in.
mreeves23
Big Hog Customs, LLC
Sep 15, 2011
91
Poseyville, IN
I use an impact as well to get the bolts out. has always worked fine for me. As stated, turn the wheel to access them either. Personally I would stick with Timken bearings if it was me. i have tried just about all types and timken is the only ones I use now. The only ones that I have had hold up for long periods.
