Name that wire game!
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
Went to get rid of the un needed parts in the dash (heater, A/C, Radio) in the new truck, and look what I found. Almost every wire in the colum was cut, and the connector was dis connected. What are these wires? Looks like i need a new colum now, since the shifter and blinker were cooked.
Max Power
Mar 16, 2007
72
Manitoba
Pink = Ignition
Orange = Accy - heater
Brown = accy 2= radio
Yellow = starter
Red = Power 1
Red/white= power 2
White = Ign 2 - trans
It also looks like it had a remote starter tapped in and later cut out. I believe it was a DEI product.
What do I win?
Max Power
Mar 16, 2007
72
Manitoba
No problem. From left to right top to bottom.
(Not used) - (elec brake) - (not used) - (not used) - (Air Temperature Assembly-Inside,Blower Motor Control Processor,HVAC Actuators,Inside Rearview Mirror)
(Door Courtesy Lamps, Driver/Passenger Seat Modules, Heated Seat Module-LR/RR, Rear Window Defogger Grid, Automatic Occupant Sensing
) - (Rear Defog) - (Courtesy Reading Lamps, Garage Door Opener, Inside Rearview Mirror, Vanity Mirror Lamps)
(Relay not used) - (Driver/Passenger Seat Modules) - (Front Passenger Door Module (FPDM),Window Switch-RR) - Not used - (Rear Seat Audio (RSA) Module, Onstar Module,Audio Amplifier (Bose))
Anything else? Ok that one wasn't off the top of my head. :D
9,905
151
Oh my GOD!!!
2,084
If anyone's gonna know what the column wiring is, its Tony. Among other things, he installs Astrostart remote starters.....
Looks like that hack job caused some major electrical shorts.
2,084
It should. I cant remember if the SWControls needed another harness at the dash or not. The wiring on the 06/07 classics should be exactly the same.
