n2o ?'s
Jscherbs
PIN IT TO WIN IT!!!
Oct 27, 2009
753
Canton, MI
Getting ready for a local track day and I'm again wanting to hit an 11. To help this happen Ive ordered 4 drag radials from M&H, a BT dieselworks lock up box and loaded my max effort tune from Duramaxtuner.
Stock injectors & cp3 hold 23k rail and clear up MOST of the smoke. Bringing up boost it smokes like a freight train but at WOT its almost all burned up.
I ran 12.20 at 110 fuel only, no lock up no drag radials. I'm going to try and hit 11.xx fuel only but if it doesn't happen I would want to spray it a little bit to get it there. I have a buddy willing to loan a .125 noid -4 line and whatever jet I need to feel comfortable. Ill probably use .040-.055 jets.
Should I bolt it up and possibly use it as a fail safe in case I don't get the 11 fuel only? I'm just not sure if it will be a waste of time with my current fueling situation and having a TON of air already from my twins. Id rather not go through all the hassle of installing/attempting all of this if someone else has already been there.
Any inputs appreciated.
Jscherbs
PIN IT TO WIN IT!!!
Oct 27, 2009
753
Canton, MI
Yes it is...
But its been running everyday within 5-10Hp for the last 4 years like this and it seems to take it.
2005LLY
Sep 18, 2011
379
I've sprayed mine pulling in my big tune, used a .88 jet my stock rods are still straight lol. I'd put you a .40 in it and say F it!
Jscherbs
PIN IT TO WIN IT!!!
Oct 27, 2009
753
Canton, MI
My head bolts, gaskets and rods have been seeing 60psi boost for quite some time. I was told it would let go long ago. My original 110k injectors are in too bad of shape either lol
Jscherbs
PIN IT TO WIN IT!!!
Oct 27, 2009
753
Canton, MI
We're you running stock injectors when u pulled? What turbo? I've herd spray makes the sled gitty up and go! :-D
Jscherbs
PIN IT TO WIN IT!!!
Oct 27, 2009
753
Canton, MI
I honestly don't care if the motor lets go. This is not a will it blow up thread...? I'm just curious if I would see enough gain on stock fuel with my current air to justify bolting it up.
Dirtymaxx03
3,109
Spray it. Don't hit it too soon and wait till she's spinning some rpms and your rods should be fine lol:roflmao:
Jscherbs
PIN IT TO WIN IT!!!
Oct 27, 2009
753
Canton, MI
3500 probably won't be enough but we'll see. I have 3 events coming up all of which the bottle would be a nice addition. Already got the paddles waiting on the radials ImageUploadedByTapatalk1372644609.279258.jpg
joe@HSPDIESEL
Jun 25, 2013
220
Hey buddy good talking with you the other day, give us a call we can hook you up with anything you need nitrous! We can fill your bottles for ya too! :thumb:
