Most likely will be running N2O on my truck in the spring. Was going to go with a different turbo but thats probably out. I have a few questions. Are you guys running a different waste gate than stock on your turbo? I was thinking that either a larger waste gate or running the stock gate at stock boost levels would help out with drive pressure issues. I was going to run the ppe boost valve on #2 and then when I spray it putting in a bypass to run the waste gate at stock boost levels so the excess pressure would bypass the turbine and not be so restricted that way. Any insight would be appreciated.
