theres been a lot of talk lately about going with a fixed vane charger. To start off, ive tried almost everything besides compounds as far as turbos go. this truck has seen stock turbo, Fleece billet 68, DTS 71.5, and the latest danville 72R vgt. on a built motor/trans truck, mods are in my signature. So far the truck before the 72r was on had lots of issues with overheating and towing was almost impossible with it on the hot months. Current hand calculated MPG with the danville 72r and other vgts was roughly 12 in town and 15-16 on the highway. Pulling a gooseneck the EGTs were around 1000-1350 constantly. Kory tuned also. spoolup was very fast, snappy and had great mid RPM range power. although the turbo brake was near non existent. suncoast 1058 converter also.
After switching the the sxe369/73/t4 i went with a wherli fab install kit along with an hx40 downpipe. Everything got wrapped in header wrap and also had a turbo blanket put on. Plugged the oil galley and went with a side of the block oil feed. switched to LBZ runners along with lbz DHD bridge. Switched to Starlite for tuning at the time also. The truck seems to get on the highway 18-21mpg hand calculated if i set the cruise and drive respectfully. itll build mid 50's in boost and be a little more smokey than the DTS and danville chargers but it lights a good bit faster than the vgts before. Coolant temps don't seem to be any issue and stay lower than before. The truck sounds much different and has less whistle, but nearly no exhaust drone at all. So far i love this charger as far as drive ability goes and is much more fun on the street than a vgt ive had in the past. People aren't joking when the say fixed vane chargers are the only way to go!
I will post findings on how it tows a loaded goose-neck after this weekend. so far this charger is great and seems to be the best all around charger.
