Going to look at a truck with 04 lb7 191,000 on the ticker for a beater farm truck. I always seem to overlook things when buying a used vehicle, so I could use some help with a list of everything I should look over.
Things I usually do.
Check trans fluid level and color
Check Balance rates
Check coolant level and color
Check engine oil level, and smell for diesel
On the drive, feel for slop in steering
make sure trans shifts thru all gears smoothly
Test to make sure 4wd actuates in front diff and Trans case.
That sums up my check list. What else do you guys look for?
Check Balance rates
