My first time !
Lennart
Not from here !
Aug 10, 2006
305
Detmold, Germany
Went to a drag race today and got to complete three runs.
Only two of them I got timeslips for, but the third was priceless as I smoked my friend with his C4 Vette many truck lenths :D:D
Here are the numbers:
1st run:
RT: 0.245
60': 1.952
1/8: 8.591
ET: 13.397 @ 102.6
2nd run:
RT: 0.036
60': 1.913
1/8: 8.526
ET: 13.333 @ 102.6
I was expecting these times, even though I should be able to do better with my light truck.
Was running on a 50/50 blend of SVO and #2. No lift pump....just not enough fuel to get moving.
I wonder though if my 60' time is good considering I ran with 305/40R22s AT tires.
Tranny shifted like a charm ! Need to look at my logged data now :D
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
Good times
What were you launching at boost/rpm wise?
I think you should have no problem getting 1.8 60's. Seems like you had some weight in the truck or were they not boosted launches..?
Lennart
Not from here !
Aug 10, 2006
305
Detmold, Germany
They were boosted, but could be improved.....2000rpm@7psi
I did not have weight in the truck, actually my truck weighs less than 6k lbs.
9,903
149
Lennart, do you need me to hand carry a PPE lift pump to you as well??:D
Awesome times!!
Where's the video at???
9,903
149
That sux Lennart. I like vids of Diesel's beating up on Corvette's and other sports cars.:D
ZeroGravity58
1,401
51
Maryland
i have the same truck, reg cab long bed. I found the sweet spot to be right around 7-8PSI of boost. I tried holding 10-11 PSI that was max before it started pushing the truck and it would just fry the driveside front tire. Hopefully my elocker will cure that...
Mar 27, 2008
178
Sheridan, IN.
1st run:
RT: 0.245
60': 1.952
1/8: 8.591
ET: 13.397 @ 102.6
2nd run:
RT: 0.036
60': 1.913
1/8: 8.526
ET: 13.333 @ 102.6
Congrats on the times
