Just got the truck a few months ago. My first diesel. Coming up on my first oil change. What oil should I go with . Thanks in advance
Also how many quarts with a filter change and is there anything I need to do maintenance wise with winter coming up. We see single digits down here in SouthWestern Indiana. Won't be able to plug in block heater at work but at home won't have a problem with that.
Good stuff?
Rotella T6 5w-40
That is what I use and I've seen -10 to well above 100 with no issues.
Corey
Do you plug yours in when you expect temps below zero?
I run Mystik 15w-50 in my LB7 and Scheaffers 15w-40 in my LLY
Rotella, Mobil Delvac, Delo 400, You can find those 3 at Walmart and should have no problems.
May want to consider replacing/flushing the power steering and brake fluid, these two fluids are most always overlooked till you have brake or steering problems...
So well it hurt anything going with a synthetic oil? I've never used synthetic before
