Should be getting close to being finished. I was told possibly by the end of this month and it will be on its way back from socal.Looking good! How's that engine coming along?
Sent from my SM-S906U using Tapatalk
That's all I used for now. Not sure if it will work correctly since I don't have any electrical in the truck as of now. Just going off of what I've seen others use. Not sure what to do with the steering wheel harness eitherDid you just use a fuse?
If your Oem steering wheel is in good shape and has all the radio/dic controls I’d be interested in purchasing it. Mine started to fray yesterday at 12o’clock and it’s driving me nuts..don’t think I could use a cover either.Well, it's time for an update. There is no news on the built motor. Today, however, I installed a new cylinder lock housing and lock cylinder.
Had to have a locksmith build it after getting him the key code from the dealership.
The waffers and springs in the old one were destroyed after the thieves messed it up. Once I got that all situated and correct, I moved on to the quick release steering wheel from NRG.
I installed the hub and pulled the steering wheel harness through and the airbag wire harness. Installed some provided wire harness to keep the the airbag dash light from coming on.
Still have some fine tuning to do, but es Como es.
Headed to Troy, Montana, tomorrow for some R&R. Hope all you guy's summer's have been good so far!
Here are some random pics of the day.
Everything on my wheel functions as it should, other then some of the lights on the steering wheel controls are out. I'll get a picture of it when I get back from Montana so you can see for your self.If your Oem steering wheel is in good shape and has all the radio/dic controls I’d be interested in purchasing it. Mine started to fray yesterday at 12o’clock and it’s driving me nuts..don’t think I could use a cover either.
Sent ya some pictures via DM.Everything on my wheel functions as it should, other then some of the lights on the steering wheel controls are out. I'll get a picture of it when I get back from Montana so you can see for your self.
Top quality. Comes with 2 rubber O rings that sit inside 2 separate grooves. One lower and one up towards the top of the fitting. Then, a retainer clip locks right in no problem.How do you like the WCFab pieces? I've been using the Dorman stainless steel ones for quite some time and been happy but I do always like to try new things.
Yeah, that's where they clipped the sheriff's cruiser when they were running from them. Seen it happen right in front on me, from 30 yards or soWow, they got that rear door good...
Anti theft device I guessOut of curiosity why the detachable steering wheel?
