LMM: My Carnage, and swap
Harbin_22
3,858
Southern Indiana
Got it out tonight. Going back with a stock motor. Funk had an extra LBZ laying around and just gonna swap all my stuff over to it and run it that way for a while. Here are a few pics so far.
Wasnt really to bad of a job to get it out.
Passenger side had a nice hole in it
What's left of the #8 rod :D
See the hole above the oil pan bolt. It broke the upper oil pan and adapter plate.
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
40
Houston, TX
well i guess if your gonna kill it, do it right!! glad to see you are getting it back on the road so quick! :thumb:
jnieberlein
Secret Squirrel Diesel
Aug 17, 2009
689
West By God
Feel your pain my truck was down for 3 months over injectors and water in fuel, glad to see you made forward progress so quickly, :thumb:
Harbin_22
3,858
Southern Indiana
It should be running next weekend. Just get to work on it after work. Pretty much only using the block and heads from the new motor. Lots of little things to switch over
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
Engine would have to be taken apart and reballanced for the new slugs,better to save the money and build his spare lower end he already has.
Aweful nice of Funk to lone that to you Kyle and good luck with the build,like i said ill be watching for your build thread:thumb:
The Funk
May 3, 2009
220
southern indiana
At the rate your going it will be running tomorrow lol..wow that was a lot if damage for no more than u was doing when she went.. I guess your truck wanted to be like mine sitting there looking Purdy without anything in the engine bay ;)
Harbin_22
3,858
Southern Indiana
It probably was jealous that yours is going to be built.
madmatt
Apr 12, 2009
1,595
"the mecca"
www.facebook.com
was blown away when i got to my shop the other day and this rig was parked there running again,,, was crazy since it seemed like just a few days before i got the "call" she let go..:thumb:
Harbin_22
3,858
Southern Indiana
Got the heads off the old motor. They are both fine,but
#8 piston isn't doing very well(#8 rod broke). The break is really clean inside. Thinking when the rod broke, it took the piston with it? The rest of them look perfect.
Haven't tore into the bottom yet, but I will check all the rods out and add more pics.
