I know I know, another build thread. This is more for me than y'all. Just my scratch pad as Pat used to say.
I still haven't even got my truck home to start ripping and tearing yet and really am not 100% sure what the problem is-I just know it's bad!
So I have a shortblock already @ G&J Diesel which I tore down over a year ago and cleaned and checked it out with a build in mind. Brad Makinen is going to get it machined and balanced and assembled for me. If I can I will go and help with the assembly but if not, he has offered to take care of it.
The block is a stock LBZ std bore which will require just a light torq plate hone.
I will be using the stock crank that came with and have it keyed as well as the stock cam.
Also I will be using the stock balancer.
For rods I am going with Cunningham
Piston's will be Mahle Cast Race 16.8:1 CR
Heads I will be re-using my stock heads if they aren't trashed and after they get gone through by Curtis @ Extreme Engine in Calgary. Only plans for heads are a set of Hamilton springs I think after they are checked for straightness, valves lapped and seals replaced.
Injectors I am planning to send to Exergy to get gone through and tips replaced with 40 overs
Turbo I will be selling my S464 along with all the piping and pedestal etc and replacing it all with a sweet set of EPR twins. S362/S475 I believe. Still hammering out the details on that but it seems like it's what I am going with.
Also I'm going to pressure test my IC and hopefully it still holds 60psi. If not, I'm going to replace it with a BD.
Trans will also be getting pulled and I plan to do a straight over exchange for a Mike L. Still working out the details there but only thing for sure is that the 5-star and stock trans is gone!!
That in a nutshell along with a pile of other mods I plan to do while the truck is down like re-wiring and relocating some components, deleting the stock fuel filter, putting in a bigger lift pump, competely re-doing the exhaust with a custom set-up is what I have in store. Lots of work and winter is coming!!
