Question: Ms And Rpm = Cad
BIG RICHIE
LBZ (ENOUGH SAID)
May 4, 2008
RENO
I was wondering if anybody knows how to take microseconds and rpm and plug them into a spread sheet or something to come up with crank angle degrees of rotation?
BIG RICHIE
LBZ (ENOUGH SAID)
May 4, 2008
RENO
THANK YOU VERY MUCH :hail:
I DON'T WANT TO SOUND LIKE A RETARD BUT I DON'T SAVVY( IIRC ):dontknow:
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
OK:
You divide RPM by 60 to get RPS - Revs per second. Minutes are useless.
Now you take that number and divide into 1 ( 1 / RPS ) and get Seconds per Rev, or how long it takes the crank to go around in a circle at that RPM in seconds.
Now you take how long the injector is open (in seconds) and divide by the Seconds Per Rev, and it gives you How Much Of A Revolution It Moved. You will need to divide the fuel shot by a million to get seconds.
Times that by 360 to get how many degrees.
BIG RICHIE
LBZ (ENOUGH SAID)
May 4, 2008
RENO
RIGHT ON! AGAIN THANK YOU.THAT JUST UNLOCKED A BUNCH OF STUFF FOR ME.
I MADE A SPREAD SHEET USING THE FORMULA (RPM * 6 * FuelShot (ms) / 1,000,000 = degrees) AND CHECKED IT AGAINST AN LLY LOG AND IT WORKED PERFECTLY.
BIG RICHIE
LBZ (ENOUGH SAID)
May 4, 2008
RENO
Here is the spread sheet. It is rather large and you might not like my RPM or MS intervals so all you have to do is change what is in the yellow boxes and the degrees will follow. If you just want a quick number use the three boxes in the upper left hand side, same thing, type in your RPM and MS and you will be good to go.:happydance:
  • MICROSECONDS TO CRANK ANGLE DEGREES.zip
Tired Old Man
Aug 15, 2007
Where ever the wind blows
Thanks for your effort. Looks great from here.
