Mr. Funnel
9,905
151
Not trying to sell, promote or otherwise peddle this thing but for the half assed character who isn't carefull with his fuel, it looks like it might not be a bad product.
Anyone ever tried one?
I think they would work well for the donkeys I work with that can't keep anything clean!!
The cheesy infomercial is pretty lame but whatever.:rofl:
http://www.mrfunnel.com/Mr._Funnel/Home.html
lotsofmiles
Father of the Van
Dec 4, 2008
3,097
Michigan
I've got one, think I got it at harbor freight. I used it a little when I was making small batches of biodiesel. It worked until there was too much water
9,905
151
What happened then? Did it stop filling because if so then that's a good thing!!
lotsofmiles
Father of the Van
Dec 4, 2008
3,097
Michigan
If you just pour straight water into the funnel in will drain thru.
but it stops draining the water as the water gets below the bottom 'cup' area.
so as long as the amount of water is less than what the bottom cup area of the funnel holds, the water should stay in the funnel
:hug:
